tweedsmith
I’m trying to recreate the EQ/Phono board work done on Ed’s Sansui repair. I wonder if you folks could vet my parts list, and answer a few questions. I'll come back and clean this up if the formatting is fudged when I post.
Here’s the list I made based off of Ed’s restoration page and a few AK posts:
Value Location Type Qant Recommendation
1uF/50V C13,C14 Stacked film 2 Ed's
3.3uF/35V C01,C02,C602 Elna Silmic II 3 Ed's --- (audio path) Is there a better replacement? Nichicon 50V is in my Mouser cart.
100uF/6.3V C606,C11,C12 Electolytic 3 Ed's
.22uF/50V C607 Stacked film 1 Ed's --- 63V OK?
220uF/50V C601 Electolytic 1 Ed's
KSC1845FTA TR03,04,601,602 4 https://audiokarma.org/forums/index.php?threads/sansui-6060-right-channel-phono-stage-issue.809578/
332kohm 1/2w R15/R16 na 2
https://audiokarma.org/forums/index.php?threads/sansui-5050-recap-component-question.986982/ Leestereo's post #7
Mouser Cart:
505-MKS2B041001C00KS
MKS2B041001C00KSSD
WIMA
Film Capacitors 1uF 50 Volts 10%
10
https://www.mouser.com/ProductDetail/505-MKS2B041001C00KS
647-UFG1H3R3MDM
UFG1H3R3MDM
Nichicon
Aluminum Electrolytic Capacitors - Radial Leaded 50volts 3.3uF 85c 5x11 2LS
10
https://www.mouser.com/ProductDetail/647-UFG1H3R3MDM
667-ECE-A0JKA101B
ECE-A0JKA101B
Panasonic
Aluminum Electrolytic Capacitors - Radial Leaded 6.3VDC 100uF SU POLAR
10
https://www.mouser.com/ProductDetail/667-ECE-A0JKA101B
594-2222-367-16224
BFC236716224
Vishay
Film Capacitors .22uF 5% 63volts
3
https://www.mouser.com/ProductDetail/594-2222-367-16224
667-EEU-FS1H221LB
EEU-FS1H221LB
Panasonic
Aluminum Electrolytic Capacitors - Radial Leaded 50VDC 220uF 9000H 8x20mm
5
https://www.mouser.com/ProductDetail/667-EEU-FS1H221LB
512-KSC1845FTA
KSC1845FTA
onsemi
Bipolar Transistors - BJT NPN Epitaxial Sil
12
https://www.mouser.com/ProductDetail/512-KSC1845FTA
594-SFR16S0003323FR5
SFR16S0003323FR500
Vishay
Metal Film Resistors - Through Hole 1/2watt 332Kohms 1%
8
https://www.mouser.com/ProductDetail/594-SFR16S0003323FR5
Questions:
I’m not able to figure out what Caps are referenced in Ed’s post: “There was a pair of tantalum caps on this board which was also replaced with Panasonic FC electrolytic. “ did I already address this with the parts above?
Out of curiosity, what are the clear looking capacitors (C05 C06 C07 C08) called, and what is their function in the circuit? They are listed as “P.C.” in the parts list.
Is it ok to go from 50V to 63V for C607? That’s the closest value I could find.
And…Probably a whole discussion to itself. The Elna Silmic II are recommended, but I only see 100V on Mouser. Is it recommended to track the exact replacement down somewhere else, or is there a suitable replacement available there (just wanting to consolidate orders).
Is what I have ok - nichicon MUSE series https://www.mouser.com/ProductDetail/647-UFG1H3R3MDM
Mouser Cart:
MKS2B041001C00KSSD
WIMA
10
647-UFG1H3R3MDM
UFG1H3R3MDM
Nichicon
10
667-ECE-A0JKA101B
ECE-A0JKA101B
Panasonic
10
594-2222-367-16224
BFC236716224
Vishay
3
667-EEU-FS1H221LB
EEU-FS1H221LB
Panasonic
5
512-KSC1845FTA
KSC1845FTA
onsemi
12
SFR16S0003323FR500
Vishay
8
Questions:
