T Somerville
Well to be honest I never checked the idle current pre re cap so it may have always been like this.
Amplifier was working good pre recap though it had a faint haze/fuzz on both channels on any setting (just enough to be annoying between songs)
So I thought I would give it some love with a re cap, deoxit and replace problematic transistors. After this the amp sounded lovely though the fuzz was still there. I thought maybe after dc offset/idle current adjust it might fix the annoying sound.
The only transistors I replaced were the 2sc1845 equivalents ( I think there was 4 in the pre amp section)
DBT did the usual bright at start then quickly down to a dim glow
Dc at speaker terminals was showing around 0v
When connect DMM to F01 for idle current after 10min warm up it started at 9mA then over the next 5 minutes it gradually rose to 70mA and then I turned the amp off.
When I connected to F02 the DMM it showed no reading at all. The DMM just showed a 1 as if it was a fault code or something.
Not sure whats going on here and was wondering if this has happened to anyone before?
Im a hobbiest and have done a few restorations on my own amps and have never had this happen before. I would be grateful for some expertise here as Im still learning. (wish I tested the idel current before recap!!)
