Penn42
Well-Known Member
I've got a 661 I'm going to be breathing some life into. After having successfully restored a 535 and 737 (thanks to help from everyone over in the Pioneer forum) my next project is going to be this 661. There isn't anything wrong with it, but all parts are original and the noise floor is pretty high. Part of which I'm assuming can be attributed to the original 2sa726's in the driver board that I've learned are quite problematic.
Currently I have gone through and cross referenced everything in the unit against the information in the service manual and marked down incongruities accordingly. I'll be ordering caps that match what was in the unit, not what was in the SM. Thanks to the giant Sansui transistor thread I have gotten quite a few of the transistor replacements figured out as well, but not all of them. I'm not sure which, if any, transistors I should leave alone. Wasn't going to touch the outputs, but what about the two metal can round ones on the driver board (2sc281) are there suitable replacements or do I even need to replace? Any other anomalies I should leave alone?
And there doesn't seem to be as much info out there for diode replacements either. It seems to be pretty common practice on the Pioneer receivers to replace diodes on the power board, but I haven't found much info as to what would be good replacements for the ones in the 661. Are the power board diodes something I don't need to worry about with this Sansui?
Lastly, what caps would you recommend for use as the filter caps? I was going to use Nichicon KG series, but I haven't ever worked with Snap in Caps before and that's all the KG series has it looks like.
Here's my current, incomplete, BOM. Red text are Parts I haven't found suitable replacements for yet. Otherwise the part #'s and capacitors values are for what is in the unit followed by Mouser's replacement #.
Pre Amp
F-1501 TR01 2sc1313 512-KSC1845FTA
F-1501 TR02 2sc1313 512-KSC1845FTA
F-1501 TR03 2sc1313 512-KSC1845FTA
F-1501 TR04 2sc1313 512-KSC1845FTA
F-1501 TR05 2sc1313 512-KSC1845FTA
F-1501 TR06 2sc1313 512-KSC1845FTA
F-1501 C01 1.5uF 25V 647-UKL1H1R5KDDANA
F-1501 C02 1.5uF 25V 647-UKL1H1R5KDDANA
F-1501 C09 100uF 6.3V 647-UPW1A101MDD1TD
F-1501 C10 100uF 6.3V 647-UPW1A101MDD1TD
F-1501 C15 .47uF 50V 647-UKL1HR47KDDANA
F-1501 C16 .47uF 50V 647-UKL1HR47KDDANA
F-1501 C25 .47uF 50V 647-UKL1HR47KDDANA
F-1501 C26 .47uF 50V 647-UKL1HR47KDDANA
F-1501 C601 100uF 50V 647-UPW1H101MPD
F-1501 C602 100uF 50V 647-UPW1H101MPD
Driver
F-1499A TR01 2sa726 512-KSA992FBU
F-1499A TR02 2sa726 512-KSA992FBU
F-1499A TR03 2sa726 512-KSA992FBU
F-1499A TR04 2sa726 512-KSA992FBU
F-1499A TR05 2sc1124 512-KSC3503DSTU
F-1499A TR06 2sc1124 512-KSC3503DSTU
F-1499A TR07 2sc281
F-1499A TR08 2sc281
F-1499A TR09 2sc1124 512-KSC3503DSTU
F-1499A TR10 2sc1124 512-KSC3503DSTU
F-1499A TR11 2sa706 512-KSA1381ESTU
F-1499A TR12 2sa706 512-KSA1381ESTU
F-1499A C01 .47uF 50V 647-UKL1HR47KDDANA
F-1499A C02 .47uF 50V 647-UKL1HR47KDDANA
F-1499A C05 220uF 10V 647-UPW1A221MED
F-1499A C06 220uF 10V 647-UPW1A221MED
F-1499A C09 33uF 50V 647-UPW1H330MED
F-1499A C10 33uF 50V 647-UPW1H330MED
F-1499A C13 100uF 50V 647-UPW1H101MPD
F-1499A C14 100uF 50V 647-UPW1H101MPD
Power
F-1500A TR01 2sc1030
F-1500A TR02 2sc1030
F-1500A TR03 2sc1030
F-1500A TR04 2sc1030
F-1500A TR05 2sc875
F-1500A TR06 2sd330
F-1500A TR07 2sc1364 512-KSC2690AYS
F-1500A TR08 2sc1364 512-KSC2690AYS
F-1500A D01 10DC-1
F-1500A D02 10DC-1
F-1500A D03 10DC-1(r)
F-1500A D04 10DC-1(r)
F-1500A D05 10D-1 821-1N5392
F-1500A D06 10D-1 821-1N5392
F-1500A D07 10D-1 821-1N5392
F-1500A D08 10D-1 821-1N5392
F-1500A D09 1N34A
F-1500A D10 1N34A
F-1500A D11 1N34A
F-1500A D12 1N34A
F-1500A ZD01 RD13E(B)
F-1500A ZD02 RD24A-N
F-1500A C02 1000uF 35V 647-UPW1V102MHD
F-1500A C03 47uF 50V 647-UPW1H470MED
F-1500A C04 47uF 50V 647-UPW1H470MED
F-1500A C05 100uF 25V 647-UPW1E101MED
F-1500A C06 100uF 16V 647-UPW1E101MED
F-1500A C06 33uF 50V 647-UPW1H330MED
F-1500A C08 220uF 6.3V 647-UPW0J221MED
F-1500A C09 1uF 50V 647-UKL1H010KDDANA
F-1500A C10 1uF 50V 647-UKL1H010KDDANA
F-1500A C11 47uF 10V 647-UPW1A470MDD
F-1500A C16 3300uF 35V
F-1500A C17 3300uF 35V
F-1500A C21 1uF 50V 647-UKL1H010KDDANA
F-1500A C22 1uF 50V 647-UKL1H010KDDANA
Pre Amp
Driver
F-1499A TR07 2sc281
F-1499A TR08 2sc281
Power
F-1500A TR05 2sc875
F-1500A TR06 2sd330
F-1500A D01 10DC-1
F-1500A D02 10DC-1
F-1500A D09 1N34A
F-1500A D10 1N34A
F-1500A D11 1N34A
F-1500A D12 1N34A
