I'm bringing a clean 7070 back to life and am getting close to firing it up - just waiting on the new output transistors and some fuses to arrive - but I've run into a possible issue with the tuner board (F-2614). One of the FM discriminator transformers appears to be missing - T03. The solder pads on the foil side of the board seem to indicate that someone pulled it. Since the alignment procedure references T03 for discriminator adjustment, I'm thinking I'll need to find a replacement. Does anyone have any thoughts about what I could replace it with. I can't find to many specs on that transformer. See photos below for reference. From what I can deduce using the HA1137W datasheet, it's has an internal 100 pF capacitor, but I can't find much else. Photos of F-2614 boards I've found show it has a white adjusting slug . . . Thanks in advance.
Rich
Rich
