Recently started working on a Sansui 790, audio on left was low. Bias checked ok at this time.
I read a forum here on the Sansui 7070 (similar model), and checked for breaks in the solder joints and the traces, resoldered just to be safe, no change.
Pulled and cleaned the relay, no change.
Now the relay will not engage if the F-2624 board is installed.
Found a rebuild kit on ebay from Ben, I replaced all the parts carefully checking orientation, checked output transistors as well, unit will still not engage the relay while the F-2624 driver board is in place.
All fuses are good.
Any suggestions on where to go from here?
Thank you
Ryan
All fuses are good.
Thank you
Ryan
