Rob Louvasz
I tried posting this in the solid state forum with only one reply. I'd thought I would post it here. I'm working on a Sansui 8, the style with no protection relay and have run into a few issues. The left and right channels both have over 24v DC on the speaker outputs. I started with the right channel. So far I've pulled F004 and F004, TR's853, 855, 857, &859. When TR852 is still connected, there is 24v on it's base and collector. When they are disconnected, there is still 24v on the "O" and "P" positions coming from board F-1278. And there is still 24 volts on the HH output point. I downloaded the schematic from hifiengine and found some differences. My F1278 board does not have the R820 resistor just a jumper and none of the transistors match what the schematic except for TR801 and 802. Also the outputs were replaced with ON semi's. The unit was recapped but not by me. Any guidance would be appreciated.
