czgeddes
Hello all of the Sansui enthusiasts! I recently acquired an 8080 (non-DB) and in FM mono both speakers work. In FM Stereo the left channel is out. The same issue occurs in AUX when the stereo/mono mode switch is toggled. The sound is excellent and the unit is completely original.
I’m going to restore it and have done a few restorations recently so I’m comfortable replacing caps, trannies etc… however I’m still a newbie.
Reading through the various threads all things Sansui 8080’s at issue are the transistors 2sc1708 on the driver board and the discussed replacement for these is the KSC1845. I have these in the FTA configuration and replaced one transistor, put the board back in place.. turned it on and it won’t come out of protection mode.
The pinout for the 2sc1708 is ECB and the KSC1845 is EBC. I swapped the emitter and base.. something I’ve done before but still not comfortable with.
What else? Any advise is welcomed
