saabracer23
I have an 8080DB that is having some very odd behavior, which I’ve sorted a lot of it on my own, but wanted to confirm this issue on the protection LED. This receiver comes out of protection, pretty quickly, maybe three seconds after power up. If I’m remembering correctly, they’re supposed to be a blinking red light and then it turns green. This receiver I’m working on obviously has a double anode diode in it so it would have two colors.
I’m getting no blinking red light and the green light is pretty dim. You can’t tell by the photo, but in person, the green diode is barely lighting.
I measured the voltage at that diode and I’m seeing about 1.3V. It doesn’t say anywhere on the schematic what I’m supposed to be seeing here so I’m trying to figure out what is wrong, is it the diet itself or the circuitry? I still have a few things to do. I’ve got bias and offset squared away, so I’m going to go through passing a signal and such but thought I would post this to see if maybe someone would have an idea, is that voltage too low?
Dan
Dan
