Sheesh it seems like this problem comes up again and again. So one stereo light was out.. I replaced it with leds and they all worked.. then flickered. I tapped the plastic case and they went on.. then every light on the unit went out. All the fuses I can see were good. There is one spot I on the plastic case that gives me caution. I will add a picture of it. The upper right top corner looks like a wire was there? I do not see any loose wires in the unit. Anyone come across this?
