Could you recommend a rebuild kit for the driver amp board?
No way! I told you, stay away from eBay. Those kits are ripoffs for the the lazy and the uninformed. The 881 driver amp kit that I see on eBay doesn't even include resistors or power transistors. I'm going to break it down to you with a list of parts I would order from Mouser if it was my own unit. The following package is sold on eBay for $19.99:
C01/C02 0.47μF/63V/5%
MKS2C034701C00JSSD Wima film capacitor ($0.79) total $1.58
C06/07 100μF/6.3V
UES0J101MPM Nichicon MUSE series audio bi-polar capacitors ($0.53) total $1.06
C11/12 100μF/50V
UKL1H101MPD Nichicon standard audio capacitor ($0.64) total $1.25
VR01/02 4.7KΩ 10% 0.5W
3386H-1-472LF Bourns trimmers ($1.56) total $3.12
VR03/04 1KΩ 10% 0.5W
3386H-1-102LF Bourns trimmers ($1.60) total $3.20
D01..D08 100V/200mA rectifier Diode
1N4148 Fairchild ($0.10) total $0.80
TR01...TR04 Differential pairs BJT NPN
KSC1845FTA ON Semi/Fairchild ($0.27) total $1.08
Total: $12.09
Those are basically the same parts and obviously cost $8 less. With Mouser's shipping fee you're still better off by a couple of bucks if you order directly, but that not the issue. The real deal is getting four matched differential transistors, so don't lazy up or skimp and buy a 20 KSC1845FTA reel and match four of them by HFE.
Now, let's throw in the best fusible replacements. I'd go with KOA Speers:
R29/R30 Metal Film Resistors 'fusible' 100Ω/1%/100PPM
MF1/4DCT52R1000F2 KOA Speer ($0.23) total $0.46
R43/R44 Metal Film Resistors 'fusible' 10Ω/1%/100PPM
MF1/4DCT52R10R0F2 KOA Speer ($0.23) total $0.46
R47...R50 Metal Film Resistors 'fusible' 4.7Ω/1%/100PPM
MF1/4DC4R70F KOA Speer ($0.10) total $0.80
Total so far: $13.81
You're still doing more than $6 better than the eBay kit. Finally, let's throw in the power transistors:
TR11/TR12 BJT 8A 250V 50W NPN
MJE15032G ON Semi ($1.59) total $3.18
TR13/TR14 BJT 8A 250V 50W PNP
MJE15033G ON Semi ($1.59) total $3.18
Final Total: $20.17
So basically, it costs 18 cents more than the kit to get the whole package from Mouser.
BTW: The white leads jumper on the voltage selector looks normal to me. It's odd the emitter resistors are all shot. Are you sure about it? How did you test the output transistors?
