Sansui 9090 Fm Stereo stopped working, Fm Reception OK
aqualogic
FM reception is fine only the stereo reception and related indicator recently stopped.
Similar but not exact issues have been mentioned in past posts, but nothing exactly like I've experienced here, so I wanted to try & get some fresh help.
My trusty 9090, not DB, has worked fine for decades. I recently went in to deoxit controls and replace various lights (related post by me uploaded).
Anyway, it was working perfectly with FM stereo beacon illuminating fine after all the work was done, but a couple of days later, the stereo signal stopped. FM comes in fine, both FM meters are working fine, other inputs are all in stereo as it should. Stereo bulb is fine. In fact this is the sole issue. Listening to FM with headphones it is in mono, so the indicator is probably working properly as there is no stereo signal.
Reading past posts suggest such things as:
adjusting VR03 muting/stereo threshold and VR04 19kHz vco both on F2549
VR01 stereo auto noise on F2550
none of these suggestions worked, in fact I adjusted back & forth all the VR's on the tuner boards with no change in performance.
any further suggestions? Thanks.
Was the tuner aligned when the work was done?
Whenever I have a fault with a tuner, I always start right at the beginning and align it.
There could be a number of issues at play, so sweeping through an alignment will identify any potential problems which could cause such an issue....
I assume you are tuning into a strong station, decent antenna etc etc .......
What gear do you have? Do you have a frequency counter to at least confirm the PLL is operating and set to 76khz?
I konw this is an old post, but ironically, I have the same issue with a my 9090. Was there ever a resolution to this?
I did go through the SM alignment process and all is well up to the tests for channel separation, etc.
