Hi all, I’m in the process of refurbing a Sansui 9090 I’ve had in long term storage. I’ve come across two mods which I’m not sure if I should replicate in the restoration or bring back to original design and hoping someone can help
Last I used this was over a decade it worked however always had a hum and recently got in the mood to refurb it
Power supply f-2431
D901 10-d1 diode cathode was soldered to the positive of 470uf c901 in addition to its pad on the board.
F—2541
Someone has put a jumper wire 39 to I think 41? Has the red wire running to f05 photo attached
Any help would be appreciated thanks
Power supply f-2431
F—2541
