Sansui 9090 power switch issue
bcbud3
Well-Known Member
I recently had the output transistors replaced on this unit. It was working fine for about 4 months. Powered my cerwin vegas no problem. Then one day, the unit would not power off using the power switch. Reliable techs are hard to find so Im wondering what could have caused the switch to burn up. Also, if needed, where can i find a replacement power switch (im in canada). Thank you
The internal contacts of the switch have been damaged and fused together by the arcing caused from inrush current over many years of use. Sometimes the switch can be disassembled and the contacts successfully dressed to restore operation.
That said, a new switch is a more sensible solution. There is a listing on eBay titled "New Sansui Power Switch w/ Snubber for Receiver 7070 8080 8080DB 9090 9090DB" being sold by a reputable member of this site that is a direct fit, and even comes with a new snubber to be installed. I d suggest getting that, and having it installed.
Thanks for your reply. Unfortunately, with shipping and exchange, that $12 switch is closer to $50. Before I bite the bullet, Any lead on a part number of a replacement?
Regrettably, I don't have a manufacturers part number, but even if it were available at a distributor like Digikey or Mouser, there is usually a minimum order (plus shipping), and with the exchange rate to CDN, will probably still be pretty costly to get one. If there is a Canadian electronics supplier that has it, maybe you could do better on the pricing. I looked at the photos in the listing and don't recognize the logo of the manufacturer, so not sure where to start looking to chase one down. The original switches were typically supplied by Alps, but the part being offered on ebay is not one of theirs.
There is a noise suppression cap across the two leads of the switch, it's possible that is the culprit. Your tech should verify it's the switch and not leaking through the noise filter cap. I just replaced that cap yesterday on a 9090 with a real snubber (cap+res in series). I replaced it because I had the tuner board chassis up to replace caps. There is a lot of space around that switch and it's a very basic looking switch, it will not be difficult for whoever does the replacement for you, make sure the tech knows about lifting the tuner chassis away by removing the 8 screws in it. And if you get the switch replaced make sure the tech installs a real snubber across it not just a noise filter cap. Canada must have some option for buying parts, I'll try a search in the box above.
A few hits came up, perhaps you could get more ideas with a post in DIY. This name did come up though: Parts Connexion in Burlington, Canada
For some reason my browser is not working with their website and I can't open the product description to look at the details of the products.
I don't think it's your browser, it looks like it should be a link, but I don't think the link works. ;)
https://partsconnexion.com/products/dpdt-push-button-switch?_pos=2&_sid=38820f868&_ss=r
Here is a link to another switch - which shows what the 'Product Description' link should look like. ;)
$11USD + $5 shipping
Exact fit and worked perfect.
^ that's the listing I posted about upthread, but didn't link to as I was unsure if it was within the rules to do so. The OP responded that due to being in Canada, it would run him almost $50 (CDN, I assume) to buy that switch. Thus, he was seeking a more economical solution. I assume the combination of exchange rate, higher shipping cost and taxes made the linked listing too costly to have sent to Canada from the US.
That (currency exchange rate: 1.39) is the highest I've seen in many years, decades in fact. I had no idea it has got this out-of-hand.
I don't think it matters where he shops, the exchange rate is going to hit him hard. Shipping within his country will certainly help.
Yes, I'd noted it had gotten bad lately but that is the worst I've seen in memory, and I remember when the Canadian dollar was valued higher than the USD. I hope he finds a solution that is a bit more palatable to the budget.
I got in touch with the people at partsconnexion for more info on the switch linked above:
The response was :
This switch is rated for 7A @ 120Vac, and 4A @ 240Vac.
The screw mounting spacing is 18mm center to center.
The 9090 uses a 20mm spacing correct?
Yes, I believe 20mm is correct. Which means drilling new holes in the front chassis to accommodate the different mounting centers. Which would be easier than modding the switch.
I do believe partsconnexion has many other switches, quite possibly a similar one with the correct spacing, I would ask them before adding work.
Check the original switch. It is not uncommon for a double pole switch to be installed with only one pole being used. The other pole [if there was one] was never used and may be fully functional. Move the switched AC leg to the unused side. It may work just fine. Move the capacitor to the other side if there is one also.
