Kevin Bailey
I've got a Sansui 9090db in pretty good condition, but both channels were coming in and out for some time (and sounded scratchy). Recently, the left channel went out altogether. I should mention that I've never attempted to service/repair a receiver. In an attempt to diagnose the problem, I cleaned the pots. A subsequent test revealed that right channel was improved, but the left channel was still out. I read some more threads on this forum and found that it might be a fuse problem, and also that the fuses need to be proper replacements or it could cause new problems. I then found that one of two fuses on one of the boards was out. The fuse is an F3A. Behind the fuse, the board says 125V7A. Perhaps foolishly, I ran out to the local Home Depot to look for a replacement and found some Bussmann 3A AGC fuses that are the same size (1/4" x 1-1/4"). The box says, "All fuses in this kit for auto, marine, or electronics applications up to 250Vac."
I'm wondering if these are proper replacement fuses. My research thus far has been less than conclusive. If I replace the fuse and the problem persists, I'll probably take it to a professional, but my hope is, of course, that this will fix it. If these aren't correct, and anyone can point me in the right direction to buy proper replacements, it'd be much appreciated.
