Sansui 9090db Found
Opus
Wednesday I found a Sansui 9090db reciever in the garbage. Wood casing is in horrible shape. Brought it home and plugged it in. Screen lit up brightly and looking good. Then I notice a red flashing light and PROTECTION!
I have never worked on audio equipment and wondering if this something looking into for an easy fix or what? Just looking for info and ideas for the next step if it can come back to life.
P.S. This Thing Is A Back Breaking Beast!!!
Thanks,
Opus
On my sansui 8080 I had some fusible resistors go bad on the driver board. It is a common ptoblem on the 8080 and probably the 9090 also. It is an easy fix if that is the problem. Another thing you could check is see if there is dc present at the speaker relay.
Here's a link to the problem I had on my 8080 and what to check for:
http://www.audiokarma.org/forums/showthread.php?t=607246
Here's a link to the 9090db that might help you also.
http://www.audiokarma.org/forums/showthread.php?t=23400
move over to sansui thread to get more input and also search for same model. it is hard to say what is exactly wrong.
need to:
get a service manual from hifiengine
measure supply voltages
then depending on if voltages are okay,
check each amps dc offset
could be a shorted output transistor(bjt)
Thanks,
Opus
Do you hear a relay"click" shortly after you flip the power switch ?
The 9090db is well worth fixing. Not working, and bad cabinet would still pull in over $400 on the auction site.
Others have mentioned the fusable resistors on the driver board, which is a very common problem to cause the unit being in protection with the flashing red light. I could also be bad outputs, and driver transistors as well. Look at the driver board, and see if you have any visibly burnt resistors. If you do, you probably have bad transistors. If you don't it may be as simple as the small grey fusable resistors. If you are not experienced in replacing parts in electronic units such as this, I suggest that you find someone who can do it for you. But if you know how to solder, and have done things similar to this before, I and others may be able to talk you through the process of replacing the questionable resistors on the driver board.
Damn! I wish I could find Sansui 9090DB's in the garbage! :P And I concur; the 9090DB is VERY much worth getting fixed. You should be happy with it after you give it the attention it deserves. Thankfully it was picked up before it was taken to the landfill! :eek:
Sansui 9090
You saved a nice Receiver get it fixed it will probably run for another 35 years. As far as the wood case goes maybe some new veneer or just remake the case. A 9090 was my first piece of gear that started me on my Audio addiction back in 1985 and i only paid $25.00 for a perfect 9090 and sold it for $500.00 20 years later. Try to find something you can buy and use and then sell for 20 time what you paid for it.
