Shole
Hi everyone ,
I'm working on Sansui 9090db for a year now ,it's stuck in protection mod , i completely repaired 2624 board all output transistors, resistors capacitors , without 2624 board receiver goes off protection mod and signal from preamp is normal OK.
I use dummy load with light bulb ( 3x40w)
I know it's long shot but if somebody has working 2624 board that I can borrow so I can test the receiver it would bi amazing .
Thanks Nick
Thanks Nick
I see you mounted a resistor on the tuner tray to absolve the heat issue of the original two 270 Ohm 5W ceramics in parallel on the board. I used a 135 Ohm 25W just like yours. I have also used pairs of 270 remotely mounted too.
