This is the 2nd Sansui 9090db I have had on the bench in the last 6 months, as well as a complete rebuild of a G-9700 in between. This 9090db is very strange. After complete cleaning and deox i powered it up on Variac and was thrilled to see it come out of protection mode right away! I have power to the PA and of course the output transistors. But no signal past the Dolby board. I have recapped the Dolby board since I had it out already. Repaired all of the pull through circuitsI The ribbon cable needed replacement after only a few days of working in that area several traces failed. I have replaced with some very sturdy new ribbon cable and reasembled. Still no signal. Using scope the farthest I was able to trace signal was Pin 2 of the BA 312 IC on the Tone control board F-2544. Now I can's see it past the the F-2654 Push Switch. Odd about that PCB as well, the traces were physically broken on the Tape Monitor 1 switch, almost like it was done on purpose. I thought that would be the problem but it wasn't! I am stumped. does anyone have any ideas? Going to start checking voltages on the boards.
