Hello! I have been playing my rebuilt 9090DB for about a month now. Yesterday I finally was able to turn it up to see how she sounds on a higher volume.
I did a full recap, replaced fusible resistors on the driver board, replaced some diodes, rebuilt the bridge rectifier, fixed the through holes on the Dolby Board, correct deoxit on the pots, DC offset, Bias, and some others. My Klipsch Cornwalls have had their crossovers rebuilt. I also fixed up the EQ.
The only problem I ran into during my rebuild is the trimmer pot on the driver board was put in and set to a setting which immediately took the receiver into protection. I had to put the original TR05,TR06 transistors back in. I currently believe this to be primary suspect.
The problem, video provided below, becomes more apparent at a higher volume. I've also noticed the receiver pops sometimes when turning on or off. I would love to have this receiver breathing well.
Please share the wisdom!
