markallen
Luddite Tendencies
Another thread on a 9090db that won't come out of protection.
Got this unit with failed L channel. Easy to see some of the problem on F-2624 board, as a number of components clearly smoked. Replaced burned driver board components and tested/replaced others described here on AK as usual suspects. Checked DC & bias VRs off board, all seem to range as they're supposed to, though I plan to replace them. Also tested main outputs, some also failed, so replaced all with MJ21193G/94G. Won't come out of protection, red LED flashes steadily. I'm using a DBT, and the bulb glows, but not brightly.
1. Can't set DC at speaker terminals, so checked bias. Still using the DBT, F4 = 43v, F5 = 84v. Bias trimmers don't seem to affect readings. While nothing was obviously smoking/burning, some driver board components got hot enough during this short time so you could smell them. Wondering if I now have more failed component(s)!
2. After reviewing another thread, I unplugged the driver board and the unit comes out of protection. Does this definitively isolate the problem to the driver board? I've resisted the temptation to plug in the F-2624 from a working 9090db I have to see if the non-working unit comes out of protection; I suppose the wisdom of such an action depends on the answer to my question of the previous sentence.
Also, likely unrelated: I've been reading about R13/14 on the F-2657 board. Per the SM, these are supposed to be 4.7 ohm 1/2w fusible resistors. On both the units I have, R13/14 are 10 ohm 3w ceramics. Are these mislabeled in the SM? Seems they might be confused with R25/26, which are listed as 10 ohm MR (not sure what type that is).
Would really welcome help on next steps to take, thanks!
