Hello all. I’ve recently picked up a 9090db free off the curb when it was waiting to be picked up by the garbage man. I thought “no way is this even going to power up”, but I brought it home and blew it out with an air can. Checked all the fuses I could find with a multimeter and they all showed continuity. So I crossed my fingers and plugged it in. Lo’ and behold it fired up and sound came out of the speakers! However the sound is very muted. There was very little scratchy sounds when I played with the knobs and buttons, and a can of DeOxit later, almost none of that. However, it is still very quiet. Like a 2 watt stereo. Everything else seems to work. The volume knob gives a linear increase of sound from zero to the muted max. Balance knob works. Tone controls adjust sound as you would expect. I hear a difference when I adjust the Dolby knob. It’s the same with the headphones. Everything works, it’s just very muted. Tried A, B, and C speaker terminals. Speakers are known to be good. I tried different jumpers from preamp to main. Same result in the AUX and Tape inputs.
When I touched the jumpers very loud hum and suddenly AM radio was coming out.
. So the problem is not the amp. Is there any benefit of hooking this up in reverse?
