Hello audiophiles,
Have a Sansui 990 receiver that I am restoring for a customer. The unit exhibits an intermittent noise, squealing, cracking and popping sound on the left channel. I cannot tell if this was one of the original problems because this unit had serious distortion issues when I got it and it was generally noisy with very dirty controls.
Here is what I have accomplished:
V/R,
Rick
- This problem is so intermittent that it could be 30 seconds to 30 minutes to an hour before it shows up and it is only the left channel and only lasts for 5 to 10 seconds. My scope shows this as square waves in nature, positive and negative.
- The distortion problems were due to the fuse resistors on the 2436 driver board; several were marginal in resistance and a few were almost open. Replaced those defective components with metal film resistors. Also, replaced the input/output capacitors with Nichcon/Wima.
- I did have most of the driver transistors, zeners and diodes for the 2436 driver board. And one by one, swapped those. Reduced the overall amp hiss slightly, but did not change the overall problem I am left with.
- I eliminated the other circuits such as the tone board, volume, etc., by removing the jumpers on the main in/out to drive the power amp only and I have no signal at the inputs.
- I also swapped the left and right channel driver transistors and replaced the thermal grease and MICAs while I had them off. This did not solve the problem. Thus, I assume that it is on 2436 driver board.
- Since I was restoring this beauty, I went forth to replace aging capacitors, components, relay and lights throughout the rest of the receiver. Cleaned all the controls. Everything else is fine.
- Power supply main caps (6800uf, 71v) and bi-polar used at the fuses (4.7uf, 80V) PS caps are on order. The existing 6800uf caps are fine, but since I am in the unit, they will get replaced.
- Offset and BIOS are dialed in.
V/R,
Rick
