Hello Everybody,
I just received a Sansui 990DB (my company was about to trash it) along with a Sansui SR-626.
The problem I have now is that there is absolutly no output whatsover. In addition the tuner also does not pick up any Signal (or at least the meter wont show it).
It will go out of the protection mode (light turns green).
I have tried supplying the power amps directly with a signal from my phone. Also nothing
I have read a few threads already. I checked (as fas as I could) the Tuner Power Supply. As far as I can tell there is no Voltage arriving there.
I have checked all five fuses on the the main power supply board. They seem to be fine.
I am a bit at a loss at the moment. Any help would be greatly appreciated. What would be the best way forward? What to check next?
How do you measure the voltages on the main power supply board? It is quite hard to access anything. (Plus i am a little afraid that i might touch the main caps and get a shock
Attached are a few pics.
Thank you and all the best from Vienna.
Ferdinand
Ferdinand
, you should be fine. I personally put the fuses in there to protect the transformer "just in case".
