Sansui A-60 question
Im English and dont like dude, but I dont throw my toys out the pram about it. Get over it.
Hemispheres; Go ahead and spout off like that in the Sansui Forum and you WILL get SHUT DOWN! Just a friendly reminder. remember "ALL AUDIO, NO ATTITUDE! Dude. (which is one U.S. analogy to the Aussie "MATE")
I just need to tell you my story, about buying A-80 Sansui :). In the flea market they asked for 25 euro. It was very suspicious, especially when I took amp in my hands, I could clearly hear something inside, like broken plastics or so. Wondered what might be wrong with it, but they refused to let me use my screwdriver to check it inside :). So I took a risk, and bought it. When I got home I tried to turn it on. What I get was just lights and no sound at all. But on the other side, amp is really beauty, and that was one of the main reason I bought it. When I opened it, noticed it was repaired before. For example, that "expert" rolled wire around emitter resistors, I guess he hadn't proper spare parts. Shape of the amp was not so good. It looked dented on the back side, and I assumed someone might dropped it by accident during transportation. And then finally I discovered why it doesn't produce any sound: circuit board was broken on two sides. So first of all, I used Loctite super glue, to physically connect parts of board that are broken, and later fixed copper traces that were destroyed too, on the same places. Result? Connected CD-player, and measured voltage at speaker terminals to make sure there is close to zero volts DC, and then I connected Pioneer speakers 150W 8 ohms. Sound was amazing! One of the best sounding amps I have ever heard! And that VU-meters are so beautiful. I couldn't believe my ears, that something that went through so much troubles, sounds so amazing!
So anyone, if you have doubts in Sansui, think twice ;) I just love that amp! A-80. My next plan is to disassemble it completely, so I could straighten everything dented :)
Cheers!
Sansuis distort plain and simple. They have always had a muddy sound designed to replicate tube amp sound and they do but they distort at high volumes.
If you want it to sound great, keep the volume low as you would if your granny were in the room.
Get any other amp and it will be fine.
Really??/That is ridiculous.Sure not a good intro to Audiokarma.
I also want to offer a defense for the Sansui A-80. When I purchased my first one, I was very disappointed in the appearance, the faceplate looks great, but the side panels are plastic and the case is not very deep. I thought, oh crap, I've been snookered. But I went ahead and restored it to working order and connected it up to my main system. I was blown away on how good it sounded. It did have a deep rich sound that I liked a lot. And this was a refreshing change from some of the other amps I was familiar with. It didn't sound muddy, I've heard plenty of muddy in other amps, mostly because they probably needed new capacitors. As a repair tech, my biggest beef with this amp is that it's hard to work on. The case is too shallow, so everything is tight and hard to get to. You'll need to remove the power meters and the transformer board to get at some of the caps. But, I would not throw out this amp. It's still a keeper even with its plastic side panels and Masonite bottom cover.
Yess, Sansui A-80 is a very nice unit. Audition once and i feel the sound signature is very much similar to my AU 719,the only problem is its are not build as robust as earlier AU series.My technician told me that it does not made to handle 8 ohms below.
I own an A-60 and i love it! The A-60 was made in Japan and was one of the last "great" Sansui builds before the logo changes: i think it certainly holds its own - caps might need to be changed (as with any 30+ year old amp) any pot dirt will wreak havoc further up the signal path BUT the primary reason this is such a classic is the build quality INSIDE: they got a little cheap with the exterior by using plastic etc..but the "guts" are what matters and the DC Servo signal is super clean sounding!
I have my A-60 pushing Infinity Reference 5's and all i can say is "WOW"...they must be a perfect efficient 8ohm match for the Sansui because i never get the volume past 3/10 for very loud room-filling sound.
There are many reasons that amps/speaker combinations sound very different etc..i always follow basic amp/speaker ohm recommendations and then of course good speaker placement etc.
I just fixed my A-60. I bought it at a garage sale with a Sharp Tuner ($100 for all). They said everything worked, but there was no way to test it, so I took a chance. The left channel worked but the right had distortion that increased with the volume. I looked at the internals and someone had put different transistors on one channel. I changed out both sets of transistors and replaced the largest 3 capacitors. It sounds beautiful now. The photo of the transistors is how it was when it wasn't working well. The 2 transistors on the right were originals, the ones on the left were something different. I found some info online that recommended these transistors as replacements - 2SC5200-O and 2SA1943-O. $43 for parts/shipping and it's all good now. I also replaced the light bulb with an LED (a pre-assembled 5V-12V with a resistor in line.)
Hi there. I have a same problem with you, my left channel are distorted on high volume, not high actually, around 9 clok. I've notice this after messing around with my DIY amp/speaker selector (trying to use pair of speaker with 2 amp), looks like both amps (Pioneer and Sansui A-60) are connected directly to the speaker, and A-60 are fried up!
Do you think replacing the left Transistor will solve the problem? Or should i check other parts? Thanks
It's hard to say that the transistors are the issue for certain unless you can test, but it does sound similar. For my A-60, I was able to visually see the issue - which was fortunate because I don't have much electrical test equipment (or completely know how to use it.:confused: My electrical tech neighbor assisted on my A-60 fix.:)). You may have done this, but it would be good to test swapping your connections and making sure the problem isn't with a speaker component or something else. If you do replace the transistors, I would recommend doing all 4 so the pairs match. This link was very helpful for me: https://www.stereonet.com/forums/topic/116598-sansui-a60-transistors Also be sure to check and adjust the bias current after working on your A-60. https://www.audioservicemanuals.com/s/sansui/sansui-a/127549-sansui-a-60-service-manual
It's hard to say that the transistors are the issue for certain unless you can test, but it does sound similar. For my A-60, I was able to visually see the issue - which was fortunate because I don't have much electrical test equipment (or completely know how to use it.:confused: My electrical tech neighbor assisted on my A-60 fix.:)). You may have done this, but it would be good to test swapping your connections and making sure the problem isn't with a speaker component or something else. If you do replace the transistors, I would recommend doing them all so the pairs match. This link was very helpful for me: https://www.stereonet.com/forums/topic/116598-sansui-a60-transistors Also be sure to check and adjust the bias current after working on your A-60. https://www.audioservicemanuals.com/s/sansui/sansui-a/127549-sansui-a-60-service-manual
Hi RS-MN, thank you for your reply. I don't have much skill on electronic too, my only test equipment -and the only one that I can use is a cheap digital multitester lol-, and thank you for the link you've shared, will dig more into the thread.
Anyway, I can confirm that the speaker (Vintage PSB speaker) are OK, it sound great on my other amplifier. Small question, the manual said that the transistor you've mention (shown in picture too) is 2sc2577 and 2sc2320, if i use the replacement you've mention (2sc5200 and 2sa1943) i'm still confuse which one replace which?
Thank you and sorry for my English, not a native speaker. Thanks!
Another very good service manual is available here: https://www.hifiengine.com/manual_library/sansui/a-60.shtml
Per the manual, the large Transistors TR15 & TR16 are originally 2SC2577 and TR17 & TR18 are 2SA1102.
2SC2577 can be replaced with 2SC5200-O
2SA1102 can be replaced with 2SA1943-O
I discovered my A-60 had had different transistor pairs installed on one side. That mismatch was the issue on mine.
I recently acquired A 60. it's old and have some issues with the balance creating noise sometimes. I am also using pioneer VSX-939TX as my receiver.I noticed the following things.
1. my Sansui A60 also distorts after 1/3 volume, iam afraid it has something to do with 4 ohm car speakers being used.
2. build quality is compromised.
3. sound is sweet and relaxing but you can't call it muddy. have warm signature.
4.But when I plugged my Audio Technica mx 40, boy oh boy this amp delivers. base is defined, everything is singing at its proper place. once I regretted that why wud I bought Audiotechnica mx 40 headphones. but believe the God in heavens this amp drive them crazy.
5. vocals make singer presence, good sound stage, dynamics, details everything is awesome.
6. it beats my pioneer dts amplifier any time.
7. my pioneers speakers are with the speaker maker, let us hear how it drives them.
gave my sansui A60 a bit of clean up, the sound become a little bit warmer after it. I think it lost its mojo.
It's mojo lies in the year of piled up Japanese dirt under the hood.
Hi Aamir, if it sounds strange after 1/3 volume, you could maybe start by cleaning the pots and switches, then checking the bias and offset. I have had these little guys before and l have ran them with 4 ohm speakers at moderate volume no probs. Speakers were approx 90dB efficiency.
An amplifier clipping at moderate volume levels could mean one output transistor not capable to hold the current needed to drive the speakers. I bet the amp sounds fine with headphones only. I'd visually check the output transistors to see if they were replaced. A broken solder could cause this problem too.
Thank you dear, I think you are right, I gave it a cleaning with a brush though it did not make the bias adjustment valve rotate but I think it rubbed the bias setting head and may have raised it from one side.
However, I am not sure how can I do bias setting?
and there are only two bias setting area vor1 and vor2.
PS. now after cleaning, it is also causing listening fatigue, i think distortion has increased.
and it does not sound sweet and smooth anymore even on headphones.
Thank you guys, old sansui 441 was right, the bias settings were off. after googling and you tubing came to know how to do it. able to set bias at 1.5mv for left channel and 1.4 v for right one.
Now it has got its mojo back and I am happy with its performance. sansui really is something, never heard music like this before.
I am grateful I got sansui A60 and also got such a wonderful people like you to help.
