Ok, so let's say that I'm still in the Christmas giving mood, so this would be a second "gift"
To start with a bit of history as this seems unclear for some people, Sansui Alpha's were actually born in 1982, with B-2301 power amplifier. Indeed, not named "Alpha" back then, but "X-Balanced".
Strictly from a marketing perspective, their amps were named "X-Balanced" in 1982-1985 interval, then in 1986 that was changed to "Alpha". Technically being the same "heart" as before, so kind of "the same Mary wearing a different hat".
As a parallel joke, later on from 1990 onward "Mary" started to change a bit here and there, but still pretty much on the "make-up" side instead on the "heart"...but indeed, "Mary" got prettier, to some extent.
And if we follow "Mary" through the '90's until 1995, then we get to meet the AU-α*07MR series. And later in 1997 "Mary" was changed a bit again and we would meet AU-α*07NRA series.
Leaving the joke aside, what follows is just a summary of the comparison between MR and NRA series, exposing the "visible" change that was done in the NRA series. There could be obviously more changes, but it's not possible to track them visually.
Speaking strictly on a technical note, that would be a very short summary: NRA series has a modified VAS. In fact, this was already mentioned by me before https://audiokarma.org/forums/index.php?threads/alpha-907-limited.896129/page-4#post-14901984 and https://audiokarma.org/forums/index...i-x-balanced-amps.856879/page-3#post-14096821 , but only briefly.
This time is also not intended as a pure technical analyze, so I will try to keep it at a "general" level.
Also I have no intention to recover the service manual of the NRA series, so please don't ask that.
There is no public schematic of the NRA series that I'm aware of (not even a conceptual one), so this could be the first public schematic, even if not a complete one.
I underlined only the certain change that occurred in the NRA series compared to MR, so except for the red boxes I'll say pretty sure that for AU-α607NRA the rest of the schematic for the power-amp section matches the one of AU-α607MR.
Words would be more or less meaningless, as it was probably the case before with the earlier postings, so this time we have a simplified schematic to visualize and understand better:
For non-tech people looking at it,
CCS = Constant Current Source (in fact those are 2 Wilson current mirrors in both MR and NRA)
and
VBE-M = Vbe Multiplier (or bias spreader), aka the transistor setting the bias current for output devices
The change itself is framed in the red boxes, it's easy to spot.
Ok, now we that we have clarified also the acronyms used, we can get to the "why" point
I don't intend to speculate just for the sake of speculation, so I'll say frankly that I don't know why they did this change and what was the end-goal.
What is obvious, however, is that for some reason they wanted to increase the current in the VAS stage, and instead of using bigger devices (and slower), they "doubled" the usually ones used, being 2SC2705 and 2SA1145. Also resistors driving the VAS were increased from 1.2k in MR to 1.8k in NRA, clearly confirming the increased VAS current in the NRA compared to MR.
By the looks of it, I tend to say that they kept the same VAS devices. However, I can't prove that the "old ones" are still used here, so I don't claim that this is 100% certain.
Further we have two images from AU-α607NRA and AU-α907NRA power-amp modules.
AU-α607NRA:
and
AU-α907NRA
In the marked areas we can see the same number of devices + associated caps, so I would say that this change was consistent through the NRA range. What is further different though only for the 907NRA are the output devices and their number, now being only 4 per amp module instead of 8 as before (including MR series). For AU-α607 series were always used only 8 output devices (that's the minimal number of output devices required anyway), so there is most probably no change.
Due to the investigation done by Erden (eradoncic) back in 2004 here, I suspect that what we see here in case of 907NRA are 2SC2922/2SA1216 output devices. But it's just my guess.
If anybody want to contribute or correct me, feel free to do so
Regards
and
AU-α607NRA:
and
AU-α907NRA
Regards
So, who knows, maybe one day more details concerning any of them would show up, to form a more complete overall picture.
