Insomniac94
Hi, hope you’re all well. I’m new here & would really appreciate some help here as a novice to vintage amps.
My lovely Sansui receiver was working wonderfully the past 3 years until the right channel suddenly developed loud static & low volume. Left channel is working fine. I swapped the speakers around to confirm the issue lies within the amp.
I’ve opened up the case & noticed nothing out of the ordinary (no leaking/bulging caps, no damage to boards which are also clean, etc. All original components are still in place.
I’ve tried:
Waiting for my multimeter to arrive to start diagnosing. Where should I begin look? Should I try swapping other components between the left/right channels?
A quick google search shows either to replace input transistors or recap the entire thing. I’d like to diagnose it properly rather than throwing random parts at it.
Cheers!
Here’s a schematic if it helps.
I’ve tried:
- Deoxit on the pots & switches, working them back and forth.
- Swapping the left & right input transistors (TR601/602, TR603/604, TR 701/702)
- Swapping the signal-path capacitors (C705/706, C711/712, C801/802)
Cheers!
