Hi,
History:
The unit belongs to my 86 yr old uncle. He bought it new in the 70's. It was repaired once about 10 yrs ago but he can't remember what was wrong with it at the time. Last week i took it to a local retired electronics tech who specialises in vintage hi-fi. He said the switch was the issue and sprayed contact cleaner into it multiple times over a few days but it didn't improve.. he also serviced the other levers & pots that were a bit scratchy and they responded well. He suggested getting a small 3rd party preamp unit that takes phono/CD inputs and feeding that into the Aux input and not bothering to try and fix the switch anymore. That option will be my last resort (See photo).
Fault Condition:
When the rotary selector switch is set to AUX it works fine. (no hum, noise, volume inconsistency between channels or overall weakness evident)
When the rotary selector switch is set to either Phono or Mic it has the fault. Phono is very dirty/noisy on the right channel and passes audio on the left but it has a hum.
The Mic setting has the dirty/noisy sound on both channels & not just one.. but it's mono so maybe that is why it's on both.
When the tape monitor switch (different lever switch) is set to Playback, that input works fine as well (in this state the rotary selector switch seems to be bypassed as turning it has no effect on what you hear)
Wiggling the selector switch doesn't affect the behaviour.
Logical Assumption:
With the tape input working fine it seems to prove everything downstream is ok.. The rotary selector switch seems to be the common point of failure with just the Aux setting working while the other 2 (Phono & Mic) exhibit the symptoms i mentioned above.
Skill Set:
I am not an electronics tech but i have done a number of basic repairs over the years like switch/pot replacements, recapping old electrolytics, biasing, circuit mods based on other peoples instructions/designs.. these often involve soldering which i can handle ok. I haven't reconditioned a switch before so would need some guidance on what's critical there. I could desolder the switch if necessary but would rather not if possible.
Below is a Drop Box link for audio recordings of each speaker (couldn't upload them here as .wav file type is not supported)
the right chanel has all the hiss/noise and the left chanel has a hum after audio finishes.
Maybe from the sound you can tell it's something else?
Audio Files
many thanks for your help
