"no hay mal que por bien no venga"
Asi se habla!
Costa Rica accounts for only 0.03 percent of the earth's surface (has only 51.100km2). However it contains nearly 6 percent of the world's biodiversity
Yupe, very cool places to go if you like nature.
Ok some pointers.
./ Recapping usually do not fix much, but is a good thing to do.
Why does it go away after a couple of minutes? How can a component fix itself?
They don't, what happens is that sometimes components get warm, expand and when that happens they make contact. Same happens with hairline cracks.
Think about audio units with 3 sections.
Input (preamp section)
Amplifier section (amplify the signal of your input section)
Power supply section. (gives power to the other sections).
First we need to find out with section is causing problems
Now, you have the same problem on both channels no matter what, what are the chances that ICs have the same failure on both channels? It can happen, but is not that common.
I would start measuring the power supply section, just to be sure it is ok.
You have some 12v zener glass diodes did you replaced them as John told you?
Did you check every solder with a magnifier glass looking for cracked solder? If any doubt re solder.
Do you have the same problem with headphones? volume down? loudness off/on
Do you have a multimeter? ( no need for something fancy) any anneng or so will do.
The big job here is the diagnostic not the parts, so I don't think you will spend much more
Homework.
Google.
How single and dual linear power supplies work.
How an amplifier works.
How a pre amp works.
How to read a schematic.
Study the service manual of your unit and this text from Conrad.
http://conradhoffman.com/troubleshoottut.htm
With some time, and analytical mindset you can fix this thing. Otherwise we would be throwing stuff to see what sticks.
Sorry not to be much more help, but the truth is that I've never seen an AU-2200 other than pictures... VERY good looking unit!.
