Sansui AU-222 Hissing Noise
Fitra
I got a Sansui AU 222 (Recap & Recable) that made Hissing Noise when volume increased but the noise reduced when I set volume to middle. Also when Treble is turn all the way left (counter clockwise) the Hissing Noise is gone.
I suspect some parts in Head Amp section create these noise.
Thanks for anyone willing to help in this!
My AU222 is quiet, but all signal transistors have been replaced.
Be sure to use the tape loop input (not tape head). Aux input goes through the phono amp section for some silly reason.
The au-222 isn’t the most quiet amp you can replace all the 2sc871 transistors these often go noisy with ksc1845
It’s also advisable to use shorting rca plugs for the phono and tape inputs when not in use
Lovely amplifier enjoy it
Thanks, I will try to replace those transistor.
Oh, thanks for the info. I use DAC dongle (usually for IEM) which input should I use?
I forgot to add that even without input (No RCA connected) the Hissing Noise still exist
Can I replace the 2SC871 and 2SC871F (in phono amp) with KSC1845FTA? and 2SC733 in phono amp with KSC1815YTA?
i can get them from same (online) store
i normally buy from mouser or digi key you can get ksc1845 and ksc733 from them in the one order hope that helps
I'm from SEA, mouser and digikey are too far and this store also source their transistor from mouser and digikey and sold them at equals to 20 cents each
Cost cutting. - uses the phono stage gain to buffer or improve the sensitivity of the AUX input in this BOTL amplifier.
I plan to replace all small transistor, are these OK?
Original Transistor, TR601: 2SC871F, TR603: 2SC733, TR701: 2SC871, TR801: 2SC871, TR803: 2SC815, TR805: 2SC815, TR807: 2SA539
Can you update us as to whether replacing the transistors got rid of your hiss problem?
I totally concur about using shortening plugs on the Tape Head (see pic), it really helped mine quiet down. It's such a simple little beast, just go through everything and check each item down the line, take mesurements, it doesn't take long but be careful, I had a 2SC871 transistor go bad, even though it tested fine on its own, so it was head scratcher for a while, (replaced with KSC1845). Our fellow member Doctorhugo helped me with mine.
Not to mention, copious amounts of repeated Deoxit on all controls really did wonders. The old girl just needs a little attention and freshening up : )
Enjoy the amp, it's my favorite Sansui. along with the matching TU-555 tuner.
5340085-d71974a9-sansui-au-222-integrated-amp-serviced-adjusted-and-complete-sounds-excellent-...jpg
Suggest you do the c871 only first, the others are pretty reliable the subs you mentioned look ok if you want to do the lot however
In the end I only replaced the 2sc871 (with KSC1845FTA) both on Control Amp PCB & Main Amp PCB. Yes it has less Hissing Noise than before.
But now, there's another problem which is potentiometer for balance is problematic and I will try to change it with 100k Ohm for now.
Still, my main amplifier is National SU-7048S which has no audible noise at all
Are you thinking that changing the transistors affected the balance pot? Also, how much less hiss? A lot? Or just slightly reduced? Thanks!
