Sansui AU-317 caps
(post a pic of the solder side of that board)
Solder side looks pretty good. A you can see they replaced 4 resistors as well and they test all 4 ok.
Previous owner did some work on F- 2751 but i'm not sure if replacements has been done with the right components.
I'm posting few pics so if you guys can spot something wrong or have suggestions on what needs to be done i would be thankful.
I'm going to clean the glue with acetone and replace capacitors. Do you have any tip how to clean and polish the fascia without erasing numbers and writings?
a few more
Stains under each of them must be related then to insulators which are missing in my amp and instead i've seen in others au-317 pics. Maybe them went damaged and removed???
I have never seen any insulators under capacitors in AU-317's, some (radial) polystyrene capacitors (similar to the transparent silvery ones in your pictures) have a pink or yellow coloured base which helps them to stand upright, but these are not generally found in AU-317.
You are right, insulator is probably not the right word but If you look better they are like transparent spacers almost covered of dirt. Anyway i'm going to clean them all and hopefully it'll be ok.
Do you guys know what is the value of C30 as i think it got damaged while cleaning the glue ? If it fails would damage other components?
33pF - the same as C32, C31 & C29
Thanks very much, i have the schematics but i was looking at C30 only and that does not show the value, i didn't know it was the same as C29 which indeed show as 33p. Would that be ok? It has no polarity?
Correct, Ceramic capacitors have no polarity, the value should be marked on one side or the other - it's vanishingly rare for the value to be missing.
This is much better
Replace all four C29, C31 and C30, C32 i.e. in both channels. ;)
Work in progress, now waiting on components for a partial recap.
Maybe a silly question but do you guys know if the power cable is the original one?
