john cronin
Hi All
I bought a 317 on eBay. The most filthy dirty unit Ive ever seen but I can see it will scrub up nice.
Both main fuses on the PCB had blown etc so I just got stuck in on the restore and clean up.
Cut along story short I replaced the standard components that normally needs changing on this model. I also replace Diode 606 to 609 as I found 608 had cracked in two (Hence blown fuses)
I powered up with a variac and dim bulb but noticed the red LED was not flashing. It was on and stable and also no relay click. The relay did not engage.
I was able to set bias to 10mV and DC offset to 0V but still no relay engage and still a steady glowing red steady LED at power on. I was able to test Amp with signal generator and scope and the amplifier works fine.
I just have the Power Amp F-2754 installed and nothing else.
I think I have two problems here. Any ideas ?
