Florin_mol
A few weeks ago I bought this AU-317 MK 1off eBay however when it arrived there was no sound coming out of it. Went back and forth with the seller and ended up keeping it at a significant discount.
I've checked all of the audio inputs (AUX and Tuner) and channel outputs with no success of getting any sound out. I've also checked the headphones output and there is nothing coming out of it either.
I've opened it up had a look at the fuses and they are all ok. I've taken the front cover off, removed the washers from the pots and sprayed all of the switches and pots with Servisol Super 10 with no success. Still no sound.
I've checked then the speaker outputs with a multimeter and surprisingly enough there is voltage on the outputs. I've added an image that shows the values below.
Another curious thing is that when I touched the pre amp. / main amp. links at the back there is some buzzing going in the speakers and that's pretty much the only sound that goes to the speakers, no static as I increase the volume, nothing, just the buzz when I touch the links at the back.
The protection relay kicks in however don't know if it works correctly as I remember the protection relay on my Sansui 881 was making a small spark when I was turning it on, this one doesn't but it does the familiar "click" a few seconds after flipping the on / off switch.
Any ideas would be helpful. Many thanks!
