Sansui Au-317mk2 voltage remap
mercia_man
just need a quick yes or no on this.
I have just got my hands on an AU-317 after upgrading from my 217 ( that my toddler poured milk into.) The 317 was bought from Germany so running on 220v, it has no voltage selector on the back. I though it may be inside... so I open it up and to get to the point to I have do change the purple wire to the blue wire on the 220/240 diagram. Just need a little reassurance on this.
I requested that this post/thread be moved here from "Vintage Gear - Top Performers" not the right place. (with thanks to the moderators :thumbsup:).
Unfortunately, I am not familiar enough with the model in question to give you an answer to your question, but I am sure someone who is will be along shortly - please be patient.
PS: What happened to the AU-217 ? - concerned Sansui fans want to know. :)
My 2yo poured milk into the top and I was told that it was a write off. But keen to know if I am able to fix it.
Thanks for moving this here, much appreciated.
That AU-217 should be fixable, patience and the right cleaning technique, with the right cleaning materials will do it.
What I would do...
First pass, warm water with just a little mild soap, then copious amounts of warm water (no soap).
Use your nose to see if all milk smell is gone, then drying, more sniffing and repeat. :)
Finally, standard DeOxit perhaps, and definitely Faderlube.
