Sansui AU-517/717 Headphone Jack (Non-standard)
Leestereo
Does anyone have a source for the headphone jack used on the AU-517/717? It is not the common type with a threaded collar, but rather it is attached via a 2-screw bracket.
That does look similar to the headphone jack that Leestereo is looking for. And a good shot of the front and back that shows where the three wires attach. Although the AX-7 seems to be an Audio mixing amplifier, so not sure if the electronics would be compatible or not.
looks like it might be possible to use the metal bracket on a threaded one using a thin nut to secure the bracket .
