Sansui AU-517 power voltage differences than the service manual
ReisDaddy
Hello all, i just bought this Sansui AU-517, and have difference voltage than the service manual. Sound is ok, should i worry? I just do a full electrolytic recap except the big one and in phono board / EQ board (F-2723).
I'm not apro EE. just a bit knowledge.
Here is my tested point in some area so far and my notes
(blue marking is left channel, red marking is right channel, pencil marking is real result from multimeter)
Position (Left Channel)Service ManualDigital Multi MeterPosition (Right Channel)Service ManualDigital Multi Meter
0135.541 vac0235.541 vac
0335.541.2 vac0435.541 vac
C05 (+) 4650C06 (+) 4650
C07 (-)-4649C08 (-)-46-50
15 31 3216 31-31.8
19-31-3220-31-32
From the transformer already far? 41vac instead of 35.5vac.
Here is the driver board F-2721 (left) and F-2722 (right)
That im focus the voltage from power supply
BoardPositionService ManualDigital Multi Meter
F-2721125155
04-51-55
F-2722125155.4
04-51-55.4
No distortion to my ears.
Should i worry?
Thank you for your time guys.
Please help and ask what another information should i prepare.
Your schematic is for a 100 vac Japan model.. What is your local mains AC ? If its more than 100VAC that would explain the slight increase in your other voltage readings.
@avionic @dimanag Wow... it solved! Changed to 240v, then all close to the service manual. That in service manual 31, my reading 32, now is 31.2, theother area that in service is 46, my reading was 49-50 now is 46.ish.
Thank you so much guys. I can sleep well now... :hug::beerchug:
