Common Beat
Hello. I've been fussing with this AU-517 back and forth I've kind of hit a wall. I'm getting a very anemic sound through the left channel only and it's 100% happening in the preamp somewhere. I've already cleaned all the pots, switches, and jacks front and back. I've replaced the fuse resistors on the power amp board and reset the DC offset and bias, and I've resoldered the header pins that attach the various boards together. For a while these things made it work perfectly, but then it went back to a distorting and anemic left channel. I've patched signal straight into the power amp and it's clean and clear as a bell so I know the problem is focused on the preamp board and I've focused my efforts there. On that board I have tested resistors, transistors, caps and even reflowed all the connections on that board and it's still distorted. Quite a strange problem as the right is totally fine.
Looking for any advice on how to get this thing working correctly because it's starting to drive me nuts!
