pcrosewood
Hello everyone.
I've been spending some of my housebound time getting my Sansui AU-5500 up and running. When I received it, The relay wouldn't click on and a few of the fuses where blown. Over time I replaced open transistors, a couple scorched resisters, and most of the caps on the driver and power supply board. Also recapped the tone control board. Checked all the circuit solder and redid any suspicious looking solders. Also replaced the relay. I'm to the point where I can get sound out both speakers but it is horribly distorted. Might mention also I need to turn volume up quite high to get the sound out but then can turn it down and still get sound. This happens on all settings...phono, aux, tuner.etc.When I use the 5500 as a pre amp, it works great. Using another preamp and the 5500 is terribly distorted. So, the pre is good, the main isn't.
Any guidance or suggestions would be greatly appreciated.
