Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
hi sansui experts, just wondering if there is a known method to perform an output adjustment on a sansui au-555 without using a scope? There is a method described here for the au-555a but not sansui au-555? Thanks!
Ok thanks I'm familiar with the process for the 555a to set the centre voltage is it the same for the 555? I presume to circa 27v off the coupling cap?
Hi
Last month my sansui AU 555 broke on left channel.
So i had it fixed by local service shop.
The result is bad.
The treble is way too sibilance and the bass got no adequate punch.
Any idea why this happens ?
Thank you in advance
