Assil
Member
Hello everyone I am currently restoring an AU-555A and facing an issue with the left channel of F1266 power board. In brief I have replaced all electrolytic caps, all transistors except the C1030, still good. I have individually checked all resistors, pots and conductivity of all copper traces.
The problem I am facing is that as soon as I power up the amp, the DBT goes bright, thus showing an overcurrent. I have removed the power transistors and carried out voltage measurements on all remaining transistors on the left channel as well as on the healthy right channel. See ATTACHED.
I traced problem to around the bias section and saw that TR805 Vce was exceeding 4 volts while the bias pot VR813 was set to a minimum. I noted that varying the pot would not affect the value of the Vce. Note that VR813 potentiometer is rated 1k and good.
The voltages on TR807 were also not normal and I found the transistor heating a bit. see voltage levels in blue in the attached photo.
For info, on the left channel, i replaced the new C984 bias transistor with a C1815 transistors. No change was found. Same issue.
Could you please advise on the matter
Regards,
Assil
