Of course Gerard is right, there is no "best".
Regarding the question, I restored an AU-666 some while ago for a customer. I thought it sounded very very nice and the customer agrees. But I also recently bought an AU-555A. I need to say I really like the "capacitor coupled" sound, precisely what the Marantz 1060 is so famous for. Still, this particlular example is "droning" a little. Perhaps it is because it had not been used for some thirty (!) years according to the former owner, so the caps might not be optimal anymore. It also might be the combination speakers/amp not being optimal. Still, apart from this little droning it sounds very musically and I would not be surprised if a recap will take care of this droning to make it sound perfectly.
I bought this amp as broken btw, it appeared someone exchanged the mains plug but forgot to connect the wires..... Still, when connected it only had sound on one channel, the tape monitor switch was responsible here. A (very thorough) deoxit solved that and now it plays fine. It's always nice if a repair is that simple
I have rebuilt both 555A and 666 and listened to them extensively (I've owned a 666 since I was born believe it or not. I own three AU-666, and six 555A/505. If you search my posts you can see some pics of rebuilds of both.
As mentioned the 666 has a bit more power, but the 555A is likely to be plenty loud unless you have inefficient speakers.
Contrary to some previous posts I think that the amps of this era are quite special. I came back to them after owning >$10k amps, and am happier than ever. But as one previous poster wrote, there is no best... but just different.
Also contrary to previous post the AU-555A sounds quite different to the AU-666 IMO. It IS similar in some ways, yet the 666 is far less warm in tonal quality than the 555A. YMMV with mods/refurbs of course (in particular output coupling caps on the 555A). The 666 is schematically closer to the AU-999 than the 555A, and it sounds it (I own au-999 as well).
Both have tone controls, and you can adjust to your tonal preference as you prefer... so maybe this is all a bit moot.
Both are great amps.
have you heard an au-717? if so is it closer to the 555 or 666? Thanks
Negative!Can anyone tell me if the AU-666 has any Black Flag caps?
I have one, too, and it's just so nice (I had it rebuilt several years ago). It drives my little Rega Aras beautifully.I just acquired an AU-666 and it's gorgeous for it's time. The fact that they provided separate bass/ mid-range/ treble controls for each channel is definitely unique and shows how they were "Ahead engineering" their components even over 50 years ago.
Well built for sure. Absolutely love their simple, refined and clean-industrial looks, too.
This joins my AU-9900, TU-9900, CA-3000 and BA-3000.
