Sticky
Hi all,
Long time reader, First time poster...
I have a Sansui AU-555A that i have had for about 3 or so years now (That i picked up at a local 2nd hand dealer for $25!), When i first powered it up, it worked fine, apart from some sratching and popping from the volume pot and other knobs, and the power button was a bit dicky, which i fixed. After a few months i developed a nasty pop/crackle/hum and would drop the left channel in and out and sometimes stop altogether. After reading a bunch of threads on here about what components to check/replace, I decided i would get it serviced professionally to give it a proper once over and spruce up. When i got it back, it worked well, minus some minor noise from the speakers when there was no output and the volume turned down, and i lived with that for about 12 months married to some Definitive BP8B's.
Now, It has more left channel issues, and i can only get sound if i run it in mono. I have reread a bunch of the threads i read initially to decide what i want to do, but im hoping to get some concrete facts about what caps/transistors/diodes/resistors and modifications i should be replacing/doing as im a bit conflicted with some of the info i have gathered. None of the main caps have been changed for what i can tell (all still Elna), Sanyo C875E8K are in place of the "flying saucer" transistors, and there appears to be some Nichicon Caps on the small board that sits behind the input selector.
Ive added some pics to give some ideas of what components may have been replaced.
Any help would be greatly appreciated.
Josh
PS: Sorry for the potato phone pics....
Josh
