Dom123
Well-Known Member
Hi everyone,
I bought a non-working AU-6900 off the bay UK. It was advertised as "low output thru speakers and humming". Based on my recent experience with my AU-7900 I figured it shouldn't be too difficult to fix.
I was hoping it would be original inside, but unfortunately all 8 output transistors have been changed to BD317 / BD318 instead of B545A / D188A. The amp has also been recapped (except big filter caps) using mutliple brands, although the majority are Panasonic FC's on the F-2596 & F-2599.
The bipolar caps have been changed to axial bipolar caps, so standing upright, with one wire folded
downwards.
I thought this was a bad sign as I had a hunch that someone had re-capped the amp to fix a problem and didn't manage. However to my amazement I found the 22V/29V output wire connectors on the 2599 board had been mixed up, even though they are labelled orange & brown !
So I fired her up on the DBT, all good then onto full mains. Relay kicks in after a few seconds. The amp works well with no hum or distortion ! One channel is a little louder than the other, but otherwise sound is clean. On good thing is that every single small transistor, diode & resistor are original. I would have thought any mishap that resulted in the outputs to be changed would have cause collateral damage, but apparently not.
The amp measures well too - No issue to dial in 18mV bias, and the DC at the speakers is only 4mV & 6mV respectively.
So my plan is to change out the fuse resistors, VD1212 diodes and change some of the caps on the tone/filter section for better quality ones.
As the DC is very low I think I will leave the 2SA798's alone, and for that matter all small transitors as the amp seems to be hum free.
Can anyone please advise if the BD317/318's are suitable ? They seem to have a lower Ft than the originals. I know the conventional wisdom is to use MJ21193G & MJ21194G, but mouser seem to be out of them, plus I don't want to spend close to 80 Euros on a set. How about MJ15015G/15016G or MJ15003/MJ15004 ?
Also is there any issues in using axial bi polar capacitors in place of the usual radial bi-polar caps ?
Many thanks,
downwards.
Many thanks,
