maxhifi
Addicted Member
I have recorded the hum before I pulled out the "suspected" tubes:
https://1drv.ms/u/s!AqmHA7OHJwtnhrgljQy-Dd85hdJBNg
Any idea?
That's not hum, that is oscillation. If you hear a noise like this you need to turn off the amplifier immediately or it can be damaged.
It can be as simple as dirty controls, bad cables, a loose wire, a bad component, dirty switches, etc. Good idea to let a tech look at it! I still think it is not the tubes.
