Hi Guys!,
I've made my AU-717 a full restoration following the amazing Leestero's post but I added some additional restoration steps like full disassembly and cleaning of all switches (tone, sub/high filters, loudness, muting, speakers and input selectors) all potentiometers (tone controls, balance which was a bit noisy) but the volume one, I removed the screws but I couldn't find a way to remove the kind of washer-spring from the back so I will leave the cleaning as soon as it becomes noisy or the grease stuck it.
AU-717 behavior before restoration:
- Permanent blinking power LED, never turned the relay on
*After PSU restoration due to massive glue destruction*:
- Considerable hum noise starting from 1/4 volume on Tuner and AUX inputs, with no input connections, speakers only
- Considerable hum AND hiss noise starting from 1/4 volume on both phono inputs, with no input connections, speakers only
- Signal "mixing" when playing something in AUX input
- Balance pot noisy and sometimes losing 1 channel
AU-717 behavior after restoration:
- After 5 secs of power LED blinking, relay is activated, altough I can see 1 additional LED blinking even after the relay is activated
- Still hum noise starting from 1/2 volume this time on tuner and aux inputs, with no input connections, speakers only, the noise intensity was reduced about 50%
- Still hum AND hiss noise starting from 1/2 volume this time on both phono inputs, with no input connections, speakers only, the noise intensity was reduced about 50%
- Signal "mixing" when playing something in AUX input still present but reduced its intensity to about 50%
- Balance pot working perfectly
- DC Offset and BIAS very stable at 0mv and 20mv respectively
Additional information and notes:
- I've replaced everything as shown on Leestereo's post except:
- I didn't replace C01 & C02 on F-2723
- I didn't replace C15 & C16 on F-2720 (I forgot to order them!)
- I replaced TR05,TR06,TR09,TR10 with KSC1845FTA due to glue damage
- During F-2663 I've removed one transformer and after the re-assembly a very small "HUM" is coming from it afterwards even though I made sure twice it's properly tight
- Checked all board voltages and all are between the service manual numbers
Would you guys have any hint what can be wrong here?
Thank you!!
Cheers,
Bruno
Thank you!!
Cheers,
Bruno
