Sansui AU 717 power supply transistors
jblmar
JBL & marantz
Anyone know the best substitute transistors for the power supply in the AU 717? Niether Mouser or Digikey can supply the original parts. Niether offers a suitable replacement on their quotes.
They also don't list the diodes as available.
Thanks.
This is for the power supply & protection board. The glue has contaminated quite a few connections and components as many of you know.
Which transistors and diodes? I rebuilt one somewhat recently, I can look and see what I used.
Yes, the transistor numbers would help.:D
2SD356 (D)
2SB526 (D,E)
2SC1708 (F,G)
2SA847 (F)
I don't have the zener diode number on hand. It's 13V, 1/2 watt DO35.
The other diode I can post later unless you have the number.
2SD356 (D)
2SB526 (D,E)
2SC1708 (F,G)
2SA847 (F)
1N5243B = 13v, ½W zener
You should easily be able to find equivalents for the transistors, quoted many times in various threads here.
Thanks. I tryed searching AK for the transistors. I must be typing in the wrong phrase.
Can you post a link?
2SD356 (D) 90v 0.8a 1w 55-300hfe noFt
2SB526 (D,E) 90v 0.8a 1w 55-300hfe noFt
2SC1708 (F,G) 90v 0.05a 0.2w 250-1200hfe 150mhz
2SA847 (F) 90v 0.05a 0.2w 250-1200hfe 150mhz
hmmm
I take it, these are feedback elements?
for gain:
512-KSA992FBU (ln)to-92 ecb 120v .05a .5w 100mhz 150-800hfe $0.05 ea
512-KSC1845EBU (ln)to-92 ecb 120v .05a .5w 100mhz 150-800hfe $0.05 ea
for current drive:
512-KSA1013YBU to-92L ecb 160v 1a .9w 50mhz 160-320hfe $0.17 (R=60-120, O=100/200, Y=160/320)
512-KSC2383YBU to-92L ecb 160v 1a .9w 50mhz 160-320hfe $0.17
then, the power devices:
to-126 for space:
512-KSA1220AYS to-126 ecb 120/a160 1.2a 20w 155mhz 35-320hfe $0.39 (R=60-120, O=100/200, Y=160/320)
512-KSC2690AYS to-126 ecb 120/a160 1.2a 20w 155mhz 35-320hfe $0.40
(the 2690 right now at mouser is more available in short lead versions)
for overkill, if you have room for a to-220:
512-KSA940TU_Q pnp to-220 bce 150v 1.5a 25w 4mhz 40-140hfe $0.54
512-KSC2073TU npn to-220 bce 150v 1.5a 25w 4mhz 40-140hfe $0.54
and for HOT overkill:
863-MJE15033G pnp to-220 bce 250v 8a 50w 30mhz 70hfe $0.87
863-MJE15032G npn to-220 bce 250v 8a 50w 30mhz 70hfe $0.87
as for the zener:
512-1N5243B Fairchild 13 V, 0.5W Zener
hmmm
for gain:
for current drive:
to-126 for space:
as for the zener:
Whew, thanks Mark. You guys amaze me sometimes....:thmbsp:
