wanguskohn
Hi all,
So I recently took on the task of recapping and replacing any visibly bad parts on my Sansui AU 717. Prior to doing the work, the amp was plugged in, would come out of protection, but no sound. I went through the boards, starting with the driver boards, working my way to the power supply board, followed by the other boards. All capacitors, resistors, visibly bad diodes (diodes touched by the glue residue) along with the relay, were all replaced in all boards (I used a recap kit available on eBay). The unit was then plugged in the unit once the cabling was back to normal to run the system through some test prior to buttoning everything up. Once plugged in everything worked. System came out of protection, and audio was playing beautifully, except one channel had muffled high end.
I can narrow it down using the balance. As a note, when I had the cables back together I did accidentally plug in the signal cables backwards. the cables coming from the Pre-Power amp switch going to the driver boards, were switched. After correcting this, and swapping them back to the balance worked properly, I did find the muffled highs followed. So to me, this would mean that the issue is not on the driver boards, but the signal path prior to the boards.
Since this amp has been pretty well gone over on the forums, and many of these unit having been rebuild from the ground up, I wanted to see if anyone could help me narrow this down to possible culprits to the muffled highs on one of the channels, and could offer any tests to run/ components to test to try and find the issue. I would like to avoid dropping the unit off to a shop for final fixing.
Any help would be greatly appreciated! If pictures would assist I would be more than happy to take some and upload.
