special_20
I have a Sansui AU-717. Due to age and concerns over glue, I have undertaken a recap. Prior to recap, the unit worked. It did take awhile to power on (~10 sec) but was otherwise in good working condition.
I started the recap with board F2721 and this is the only board I have touched so far. Following the Leestereo thread I pulled parts, cleaned glue, and replaced parts (see list below). Post recap of board F2721, the unit goes into and stays in protection upon power up.
I brought unit up initially on a dim bulb. This test registered no shorts. I switched to mains power. I have been able to bring the DC bias into spec (~20mv DC). However the unit has stayed in protection. When I disconnect power to board F2721, by removing grey and yellow wires at pins 4 and 12, the unit comes out of protection. This indicates there is something wrong with the F2721 board.
Per Comment 5 of this thread, I measured from the positive test point of F2721 to case ground. Per thread, this is an approximation of DC offset voltage. I have 52.2 VDC (yes volts!). Voltage is unresponse to VR01 adjustments.
What's my next step here, audiokarma gang?
I've reviewed my parts selections, orientation against photos, and reflowed solder.
I am limited in tools to a multimeter, ESR meter, and a component tester.
Per Leestereo's write up on recapping a Sansui AU-717 I have replaced the caps, and diodes and variable resistors. In addition, I have replaced several components that had contact with the Sansui corrosive glue.
position / original / replacement
C02 / 33uf, 25v / 100uf, 35v
C04 / 33uf, 25v/ 100uf, 35v
C05 / 33pf, 100v / 33pf 100v COG
C11 / 470uf 63v / 1000uf, 63 v
C12 / 1uf 50v / 1uf, 100v
C14 / 470 uf, 63v/ 1000uf, 63v
VR01 / 100ohm / 100ohms bournes 25 turn sealed
VR02/ 2.2 k ohm / 2.4kohms bournes 25 turn sealed
VR03 / 1kohm / 1kohm bournes 25 turn sealed
ZD01 /eqb01-22 / BZX85C22
ZD02 / eqb01-22 / BZX85C22
TR03 / 2sa750 / KSA992
TR04 / 2sa750 / KSA992
R15 / 10kohm / 10 kohm 1/2 watt
R07 / 820 ohm / 820 ohm 1/4 watt
R11 / 1.2kohm / 1.2 kohm 1/2 watt
R23 / 150k ohm fusible / 150kohm 1/2 watt Correction 150 ohm
R25 / 150k ohm fusible / 150kohm 1/2 watt Correction 150 ohm
