Start by narrowing down problem. Find a source (tuner or or other sound source with volume control, and go directly into the amplifier input jack. (Is the jumper between pre-out and main-in installed?) Since you have relay click, my bet is that amplifier part works, and problem is preamp related.
For preamp, start with the simple or obvious. Is four channel switch in right position. Tape monitor switches in right positions. Knobs on selector switch in right position (this can drive you crazy if it is off and not indicating the proper input.) Make sure you didn't put a shorting plug into one of the output (tape, 4 channel, or main out) Shorting plug is just an RCA plug where center is connected to ground, and are normally only used in unused phono inputs - not useful anywhere else) Check for negative supply voltages to preamp boards.
Trouble shooting will get tougher if no problems are found - you need something to follow signals, as voltages may not tell you the answers. Standard equipment is oscilloscope - although there are ways to trace signals without one. Several people have done it using a capacitor coupled lead and a tape deck....
