Differential amp first stage in on the driver boardwow, thanks for the detailed information. a couple follow up questions..
1 - by differential amp 1st stage, you mean the tone control board? ie: where the tone control switches are? sorry, I've not done much work on stereo amps. most of my (limited) experience is in old tube guitar amps. This is the first old stereo amp i've done more than replace a power cord or lamps in.
2 - so I'm guessing it's safe to run this amp for a while with no load hooked up, just headphones? Again, coming from tube guitar amps - that's a no-no as far as I know. Just want to make sure I don't make a stupid mistake.
I do have another amp that can separate the pre and power (2000a) - but that's my main system and is in constant use.. so I'll have to try this first so I don't have to disconnect everything and hump it down to the workshop.
thanks again!
It is safe to run solid state amps without a speaker load, kind of opposite with a tube amp
