Peter lye
Hi all.
Seeking help from AU-777 expert, recently got a au-777(junk) from yahoo. 1st Power up test with 100w DBT, bulb light up in full. I did notice the cap C002 is Blown during visual inspection, and No fuses have blown.
After change out the blown C0002 cap with a new 6800uf/100v, I power up for the 2nd time and DBT when dim. So i hook up a pair of my test speaker and it sing without any problem. Took it off DBT, do notice both the TR811 & Tr813 start to heat up.
So I follow @stereofun post to measure the bias as below :
https://audiokarma.org/forums/index.php?threads/au-777-bias-adjustment.931281/
I can get VR804 to 22mA, But VR803 I Can't get it down 22mA ,lowest i can adjust is 80mA.
VR802 i can adjust to 39V, But VR801 can only go 27to 28V
Thank
peter
On the 777 the bias does not require a scope. You measure that by probing mA across the fuse holder for each channel, then set VR803/804 respectively for around 22mA
I think what you are referring to is "main amp section output adjustment" which is adjusted on VR801/802. This does require a scope. Normally there is a "good enough method" of adjusting 1/2 rail voltage on the output caps plus to ground - however on the 777's this is not straight forward. However for the 777, you can adjust for 39-40V (40-41V for the 777D) which is per schematic the voltage you should have en that position. It is not as precise as using a scope, but it will be the best you can do without, and will certainly be an improvement in case you find two different numbers say 37v in one channel and 42 in the other - just getting them alligned per schematic is a leap forward.
So probe output caps 825/826 - plus to chassis - adjust that to around 39V.
Thank
peter
