Nuel
I am in the process of recapping a Sansui AU 7900. It works fine, but it was pretty beat up. Not sure if the sound is as expected plus there is also a cold solder somewhere in the main board. So thought I'd replace the usual prone to fail components (Caps, VD1212, fuse resistors) with new ones and run a re-solder at suspected points.
Something weird is that, the Fuses F601 and F602 had been replaced with a wire. Not sure if that was how it was or someone was in there before. Can any one help? Also I would be happy to hear anything that I must be careful about and anything that needs to be replaced besides those mentioned.
-Thank you.
-Thank you.
